Roger/Sacramento
I was attempting to run some gas up to the dry carbs (with the help of squirting gas into the carbs) and after a couple of short run ups the ignition just did a click and no fire up. I thought maybe the made up power cables did not have a good soldering job. I removed them and resoldered the fittings. A wasted effort. Maybe the battery was bad. Changed to a known good battery and the same result. I then attempted to turn the motor over with a socket at the crank and it wouldn't budge. Must be a stuck starter. Sure enough that was it. Happened once before and it is a tough job to remove. Got it done and reinstalled and it works again. I could not see any evidence of a problem with the flywheel ring or the gear on the starter although it was a little sloppy. Better order a new gear and replace. Next issue will be to take out the T-5 transmission (not going to be fun) and have it worked over. It makes a lot of noise on the freeway. Also it is difficult to get in gear at a stop sign. Have had to turn the motor off and put in gear and start up again. So much fun these hot rods.
