nhusa
The 1931 Town Sedan that my dad put in storage in in 1964 has a stuck motor.
I brought it to my home last year and have been soaking it with MMO since last fall
This weekend I finally had time to work on it
I first removed the starter and tried to use a pry bar on the flywheel without success
Then I decided to remove the head so I could push the on the pistons
Everything went OK until I tried to remove the distributor.
It would not come out even though I removed the locking pin
I finally pried up and it was spring loaded -it would not come out
Next I removed the intake/exhaust and the valve cover and found that the distributor was stuck to the oil pump shaft. After a bit of "persuasion" they came apart
Next I tried to remove the water pump and found that it that was frozen solid.
Since it has a two blade fan I was able to just loosen the radiator instead of removing it to get the water pump out
I then removed all the nuts holding the head in place.
As expected a few of the studs came out with the nuts.
Now comes my problem. - the stud on one of the two head bolts at the
front water inlet came out but on the other side I could only removed the nut.
I have double nutted the stud and can't budge it
I even tried a bit if heat without success
I can get the head to release from the block everywhere except at the front where the long stud is
I am still trying to figure out why anyone would combine the water inlet bolts and head bolts into one but who am I to question the logic of the Ford engineers?
Are there any tricks I can use to the stud out and the head off?
