vtwinsideways
Trying to separate a 9T from a sideshift trans. Moisture has had an effect on this one. Engine is stuck, clutch is stuck, spline is stuck so nothing rotates. Soaking it with PB and then ATF. Any suggestions or warnings? I am not going to use the trans, should I give in and cut the input?
