I am usually on the EV8 forum, and this engine problem may be a little to late model for this forum, but maybe the members have a solution. '74 Ford 351 Windsor engine. The engine ran great up to the point the fuel pump failed. We replaced it, and tried to restart the engine, but it turned over very slow as if the battery was low. The battery was fine, we loaded tested it. Checked the oil and and found it was overfilled/ We realized when the fuel pump failed it leaked gas into the oil pan. We changed the oil & filter, and it wouldn't turn over with the starter or by hand. Suggestions ? Thank you.
