stuck clutch
Also a gear higher than first would be better. High gear would be best, as the lower gears give torque multiplication to the rear end.
I'll try second. I don't have a lot of room to maneuver, so third isn't going to be possible.
I know not to tamper with the pressure plate bolts, but I don't know if a prior owner did. Is there any way to check without taking it out?
"I know not to tamper with the pressure plate bolts, but I don't know if a prior owner did. Is there any way to check without taking it out? "
Not really, and there is no need to unless the throwout bearing doesn't contact them evenly.
I'm in the same boat with the OP. I drove my 31 coupe today for the first time. Warmed up the engine, shut her off, then rolled her outside. Started it up in first gear and drove around for about 10 minutes with the clutch in. gassing it and letting off didn't unstick it. Getting up a little speed and stabbing the brakes didn't unstick it. So I guess you could say I'm "stuck" with an inoperative clutch. What's next?
Racer32,
Clutches stick because moisture/humidity causes steel metal fibers in the clutch disc lining to rust to either the flywheel or the pressure plate surface. IF the lining manufacturers weren't SO CHEEP & used bronze fibers instead of steel fibers, they WOULDN'T rust & STICK! YES! I have credentials, I once worked for a CLUTCH REBUILDER!
I don't know, for sure if there is room, BUT, if you have the T.O. Brg. inpection cover off, shine a light in & find the splined center of the disc that slides on the trans. input shaft.
See if there's enough room to touch it with a 1/4 or 5/16" rod, maybe 8" long. If so, while holding the clutch pedal down & rap it with a few sharp blows from a hammer. I "think" that will "jar" it loose, as it'll only be stuck only on ONE side, either to the flywheel, or to the pressure plate.
This all depends on whether there's room to touch that splined center hub on the disc with the rod. I've NOT done one this way, but I think it's a possibility.
Let us know--Bill W.
(With the clutch pedal pushed down, the disc will be free from one or the other of the surfaces & the impact should pop it loose from the other surface. Once, on an old Hillman, with a STUCK clutch, after taking the pressure plate off, the disc was still sticking to the flywheel! A tap on it with my itty-bitty ball pein hammer, & that DAMNED disc fell of & almost broke my LITTLE TOE!)
Sorry this is so looong, but it's hard when I can't talk to you & use my hands to "show" you stuff. LOL Bill W.
Bill, Tried to get in there with a punch...not much luck.
Also tried 2nd gear...drove it around the shop for about 10 minutes with the clutch pedal down. Still stuck. :(
well, an A has so much low end torque and the cars is not really that heavy......
Can you nudge or push the car up to a heavily padded tree, start in first gear, and as the rear wheels begin to spin step on the service brake real hard all the while with your other foot on the clutch
Third gear is better than second gear to drive with the clutch pedal depressed. Are you sure the clutch pedal is working the pressure plate? Did you spray any brake clean inside the inspection plate?
Haven't tried spraying anything in there. Throwout bearing moves, and the "ears" on the pressure plate are moving as well.
No trees in the parking area out front of the shop. I suppose I could use a tow strap and my truck for an "anchor" and see if I can get the wheels to spin on the concrete.
Can you take it out on the road and get it into third gear and try full throttle and idle back and forth several times? I like third because you won't be torquing on the ****** gears like in first or second. Would hate to see ****** parts get messed up also due to a stuck clutch.
This baby is stuck pretty badly.
Once you get it unstuck, if you live in a really damp area or seldom drive the car you may want to consider making a stick that depresses the clutch pedal and wedges up against the seat when the car is parked for long periods.
Be careful! Jerking the clutch loose will sometimes rip the lining off, particularly if the lining is marginal to begin with. I found this out personally and had to pull the engine anyway but, had I pulled the engine first I wouldn't have had to replace the clutch.
be careful not to blow something in the drive train trying to unstick this stubborn clutch. i have seen that happen and also in the end needing a clutch anyway.
if it was me i would spend the few hours and replace the clutch assy.
As best I can tell, the car's been parked about 40 years...it's had a long time to get stuck :). I've decided to go ahead and pull the engine and see what i've got to work with. All the front sheet metal is off, so it shouldn't be too much trouble.
great move,,
take some pics
Hey Russ, are ya still stuck-up?
Yep,still stuck. Haven't had a chance to work on her lately. Seems like the whole month of December was shot what with the Icepocalypse, trying to get other stuff done for Xmas, and getting sick the day after Christmas. I haven't even been been out of the house since Christmas Eve. Feeling more like a human bean today, though.
