wet weather and lack of driving has stuck the clutch in my 1941 1 1/2 ton truck, apart from removing the driveline, trans, pressure plate does anyone have any ideas on solving this problem. I though about pouring evap o rust in the clutch area, after sealing up the drain hole in the bottom pan and then turning the engine over to spread it aound. OK what are your ideas?
