Jacksonlll
You must be boiling over at sustained 45 MPH. If you are not boiling, after a steady 10 to 12 min at 45, then you do have a mystery. If it loses enough coolant to cause boiling, then your new core is plugged. Don't blame the pump. When people cut down the impeller, they are just reducing the pump capacity. A free flowing core can take all the water the pump can put out.
