Seattledavid
I installed a Stromberg E-fire on my 1947 Ford Super Deluxe that is 6 volt positive ground. I used the correct one and the plug wires from Stromberg also and the 1.5 ohm coil they suggested. I finally got the car to start after I charged the battery. It is running rough at higher speed. The voltage coming from the ignition to the white wire is over 6 volts but if I check the voltage on the negative side of the coil it is only about 1/2 a volt. Shouldn’t it be 6 volts?? Is that causing the rough running. Do I need to advance the spark also??
Dave
Dave
