Any ideas where I can buy the part that fits on the drivers side of the throttle shaft that acuates the hand throttle? Mine just has a short linkage which pushes the hand thottle knob in and out as you work the accelerator pedal.
Thx,
Max.
i think i have an extra one, you do mean on the fuel inlet side, on the carb base, right? if you will PM me your email address i can get a pic and get back to you.
yes its the gizmo on the throttle shaft I am after, left or drivers side of the car, same side as fuel inlet. It is a different fitting to the Holley 94 Carb.
You'll need the lever, cap, spring and pin. When you go install it, it's a good idea to support the end of the throttleshaft with a block of wood so you don't risk bending the end of the shaft.
