rustedorrotting
I am trying to restore a 48 for a man. Does anyone know the correct finish for the cast iron base?
Here is a picture of a 48. The body was also coated with a satin-nickel type of finish (obviously non-standard). I used the satin-black coatings on the base and all linkage related components.
I was tired of ugly, stained carbs (they always end up that way) - so this was an experiment. The good news is that when they get a bit gas stained, I take a toothbrush and lacquer thinner to clean them off - doesn't bother the coatings one bit.
I recently had Michael Driskell at Third Gen rebuild this Stromberg 97 carburetor. The paint is Cerakote as previoulsy mentioned. It is gas and oil resistant.
I only wish I had a bigger lathe for those occasional "big" jobs!
Yeah, me too. This one won't do wheels from the engines.
I wound up using Tool Black but wasn't satisfied so finished with VHT black after Zinc coating.
