Thx DD, I realize that. This will be something for now & later incase I decide to change again. Have a design that I’m trying accommodate a ‘48 Ford MC for use now w ‘48 ford brakes all around. Will decide later to go w either Bendix type on front or possible discs. W Bendix ‘48 MC will work fine but if I go w discs I’ll néed the Mustang duel MC w portioning valve. Want to try to modify bracket to use either.
Hi Guys, I need to know the stroke travel on both a '48 Ford master cylinder and a 65 Mustang dual master cylinder? I need the stroke dimensions for a project on my '35 Doesn't seem to be in the details given on sites for buying?
Looks like a neat little package if I can get it to fit. The strok concerns me. If much longer than the ‘48 MC will b tough.
Good stuff Brian & DD, took a while to read all & absorb. Think I’ve understood. In a system w a specific size or sizes ( some diff front to rear) wheel cyl’s, using a specific single stage Master cyl that works as should, to maintain good pedal & stopping when changing to dual MC, the new MC needs to have at least the same cylinder bore & stroke as original but bigger bore is better? Seems rational or am I still in the weeds?
Guess I didn’t get it, so w Ford / Lockheed’s on front & rear w MC u need a dual stage MC w same bore as. ‘40-‘48 single stage.
