Strange 1948 Frame Number ''HELP''
modela4shane
Can any one shed some light on this frame number on my 1948 sedan. The number by the steering box is 59T298444602:confused: . I can not seem to locate any reference to the 59T. Also their are no stars before or after the number. Thank you for any help.
59T was used by Ford as a model and as a part number prefix for postwar large truck stuff...also, the number you show is WAY high, like about 10 times production of early type 239's, so none of that makes any sense at all! A V8 '48 Ford should have something about like *899A-number in the 2 million range*...your number would still be too high if cut back to the right order of magnitude!
I would go straight to the bell housing number, in hope that car has its original transmission and so its proper number there.
There is actually an access to see that...if you look at the top center of the toeboard under the edge of your rug, you should see a long oval tab cut out on three sides. If you bend that up you should be looking at the serial pad. If you are lucky it may be clean enough to read without serious work.
Does car have a title with a number on it?? It is conceivable that this is some sort of state assigned number for a car that lost its original paperwork.
Bruce, the car was assigned a new California # by the previous owner. I did look at the trans. # but its for a 1940 ford. Im starting to think that some one changed the number , restamp I think? Thanks for you help, Shane
If you have a state assigned serial number, that would be legal and legitimate...
Is that long number what they assigned or did they put a plate somewhere with their number?
The door jamb has a new serial # tag with special rivits. The 59T2984446012 number is on the frame next to the steering box.
Bruce is it possible the frame might have been under a half ton truck at one time? But that still dose not explain the looong number. Shane
No...a half ton would have C for commercial, not T for truck, and of course would be a crude ladder-frame 4 springer. And the number is an order of magnitude too high!
At least you have a valid assigned number. Seems you are legally on good ground and have a puzzle of intellectual interest only!
On the looong number...are the characters Ford style?? 6 and 9 in Ford font would have straight shanks, the 1 would be I.
The 1 is a 1 not the Ford I. Starting to think this was a restamp at one point in its life. Thanks for your help Bruce. Shane
