shoe box Jack
will stp work in the steering box thanks Jack.
stp will leak out. Use corn head grease.
STP is not a lubricant, period.
I see from your previous posts that you know petroleum products, you must be a chemist or chemical engineer. So I need to ask:STP is not a lubricant, period.
use 1/2 synthetic grease mixed with 1/2 synthetic trans doping mix up and force into box until it is full drive around and check the level. will not cook off like regular doping and as said before it is like power steering
