Nope, used it in a freshly rebuild Model A transmission. PERHAPS......the first post tried using it exclusively without the "proper" transmission oil??? MAYBE when used in "conjunction" with and as a 1/4 amount supplement to the transmission oil then its a "different" out come? Just an thought!!! OR maybe the product he used "isn't" as much like STP as he originally thought???I would imagine that the differences are due to the condition of the respective transmissions. If used in a transmission with a fair amount of wear, it is possible that it might help a little, while with a freshly rebuilt transmission or one in otherwise good shape, it might be detrimental. When I was in college with no money, I used it a lot in my "beaters" and it literally kept them running. The last thing I would do is use it in a new car.
MR TexasSTP is not a lubricant. It thickens oil but dilutes real lubricants. Can't understand why I keep seeing posts about snake oil!
Lots of anecdotal stories, but no scientific facts......yet......maybe a chemist who knows about lubrication will chime in to clear this up.
BTW......I used STP in a Ford 312 engine for over 200K miles......the body rusted away and it ran like a clock when I sold it to a guy who put it in a fishing boat (not for the anchor!!).
I pulled the rocker covers frequently and never found any sludge.
in my model A i used 600 wt ,which is what it calls for ,it’s available at snyder’s or brattens antiques ,also in my 50 cpe ,i use lucas engine oil supplement in the overdrive trans and diff 22 years no problem ,but i don’t drive them in the cold ,and i don’t use the lucas straight ,mix it 50/50 with 90 gear oil
Use John Deere Corn Head grease. I had STP in my 32 box two years ago, did not like it and it leaked out very slowly.
Glenn
Interesting. I have my '32 box filled with straight STP right now. Maybe I'll drain it out and add Corn Head instead.
