stovebolt
john hamilton
Why do they call Chebbys stovebolts? These are ALL of the headbolts for an old Chebby. They are 1/2" coarse threads 5 1/4" and 2" long.
If you are benefiting from Ford engineering pat yourself on the back. This is from an early 4-cyl head that they used on Model T's for racers.
If you look at an old potbelly coal stove or larger coal kitchen stove you will see that they are bolted together with large bolts similar to what was used in a chebby. Hence the name. Also, on a chebby engine they are much more prominent than on some other engines.
The sides and valvecover on the old sixs were held on by 1/4" course thread screws commonly called stove bolts.
Round head slotted bolts are still called "stove bolts". They were mostly used to hold the sheet metal cover on the right side of the engine.
