I’m just getting a chance to check it again. I ran a jumper wire straight from battery to stoplight switch to check. Brake light works but now my dash lights come on am I press the brakes. If I turn on headlight’s and press the brakes doesn’t seem to work. Only when headlights are off. Both filaments are still on when I turn on headlights. All of my wiring on the firewall look correct. The green is hot on both ends of connectors. As stated before, they have been working fine for years.
Seems like you haven't traced green wire from the brake light switch back to the circuit breaker and you probably have a green wire abrasion to one of the headlight wires, feeding power to the green wire.
Do you have a VOM and know how to use it?
How To Test a Wire for Continuity
Touch one of the multimeter (VOM) leads to a male prong and insert the other probe into the corresponding female receptacle. If you get a zero reading, the wire is unbroken.
After checking the other wire, cross-check by touching the probe to one of the male prongs and inserting the other probe into the opposite receptacle. You should get no continuity. If you do, it means something sliced through the insulation and the wires are touching each other.
You can also test a lamp wire by touching one probe to one of the male prongs on the cord, the other probe to the light socket, then turning the switch on and off. You should get continuity with the switch on, and no continuity with the switch off."
- The VOM will have an Ohm symbol, Ω. Switch to Ω to check resistance.
- Check the resistance from the brake switch back to the circuit breaker.
Write it down. Alligator clips are handy for this.
- Follow the green wire from the brake switch back to the first bullet connector.
- Unplug the connector and write down the resistance from the switch to the bullet
- Check the resistance from the female connector back to the circuit breaker and write the value down, etc.
- Check the green wire for abrasion especially where it crosses other wiring. You may find that the headlight wiring is contacting the green wire.
Please make a quick sketch, noting connectors.
Post this along with the Ω values for each segment.
Glenn
