RudyOnWheels
Hello all, I am new to the world of Model A ownership, but have loved them since I was a kid. I just got my coupe about a month and a half ago. When I went to look at it, it started right up everytime for the owner. I appears to be a mostly original car. I printed off the starting instructions from the MARC website, but it never seems to want to start.... It eventually will, but it takes an excessively long time. The guy I got it from said he does not bother with trying to adjust the fuel mixture with the choke rod. IO have tried it both ways, and it doesnt seem to help. Going by the MARC website, this is what I do, and I have to crank, and crank and crank for a few miunutes before it eventually sputters to life.... Today we took it apart and put on a new exhaust manifold gasket and gland rings, and I put a gasket in between the top and bottom of the tillotson model X carb. Also one between the carb and manifold. When it runs, it runs well. It is just impossible to start.... This way doesnt work, so i try this, then that, then this, and can never figure out what really works. After re-assembling it, and trying to start the car, fuel kinda pours out of the carb where the filter would go...... What do you think the issue may be? bad points? condenser on its way out (or died today)? How do you go about starting your car?
Here is what I do, according to the MARC website, and it doesnt seem to work.....
STARTING THE ENGINE
1. RELEASE THE LOCK CYLINDER BY TURNING THE SWITCH KEY TO THE RIGHT AS DESCRIBED ON PAGE 6.
2. SEE THAT THE SPARK LEVER IS RETARDED; THE THROTTLE LEVER ADVANCED THREE OR FOUR NOTCHES ON THE QUADRANT AND THE GEAR SHIFT LEVER IN NEUTRAL POSITION.
3. IF THE ENGINE IS COLD, TURN THE CARBURETOR-ADJUSTING ROD ONE FULL TURN TO THE LEFT TO GIVE IT A RICHER MIXTURE FOR STARTING. THIS ROD SERVES BOTH AS A CHOKE FOR STARTING AND AS AN ENRICHING ADJUSTMENT.
4.NEXT PULL BACK THE ROD, AT THE SAME TIME PRESSING DOWN ON THE STARTER BUTTON WITH YOUR FOOT. THE INSTANT THE ENGINE STARTS, WITHDRAW YOUR FOOT FROM THE STARTER BUTTON AND RELEASE THE CHOKE ROD.
5. NEXT ADVANCE THE SPARK LEVER ABOUT HALF WAY DOWN THE QUADRANT.
6.WHEN THE ENGINE WARMS UP, TURN THE ADJUSTING ROD BACK TO THE RIGHT. NEVER DRIVE CONTINUOUSLY WITH ADJUSTING ROD MORE THAN 1/4 TURN OPEN. (SEE ADJUSTMENT OF CARBURETOR, PAGE 24.)
WHEN STARTING A WARM ENGINE, DO NOT PULL BACK THE CHOKE UNLESS THE ENGINE FAILS TO START ON THE NORMAL MIXTURE AS THERE IS A POSSIBILITY OF FLOODING THE ENGINE WITH AN OVER RICH MIXTURE OF GAS. IF YOU SHOULD BY ACCIDENT FLOOD THE ENGINE, OPEN THE THROTTLE AND WITH THE CHOKE ROD IN NORMAL POSITION, TURN THE ENGINE OVER A FEW TIMES TO EXHAUST THE RICH GAS.
Thank you very much for your help.....
James
STARTING THE ENGINE
James
