Stock Ford cams
Jim, here's a start with some stockers. Wayno
49-51 ford "B" cam
.305 lift
int. opens 5*btc - closes44*abc set.017
exh. opens 48*bbc -closes3*atc set.019
52-53 ford "E" EAB cam
.328 lift
int. opens 21*btc - closes68*abc set.017
exh. opens 56*bbc - closes11*atc set.019
49-50 merc "8CM" cam
.338 lift
int. opens 10*btc - closes50*abc set.014
exh. opens 50*bbc - closes10*atc set.016
51-53 merc "1CM" cam
.333 lift
int. opens 5*btc - closes51* abc set.017
exh. opens 47*bbc - closes9* atc set.019
Jim, here's the DeLong in my Bonneville car.
DE LONG RACING CAMS
GRIND # 7212-16
SUPER FULL RACE
INTAKE OPEN 34 B.T.C.
DURATION 288
INTAKE CLOSED 74 A.T.C.
EXHAUST OPEN 78 B.B.C.
DURATION 288
EXHAUST CLOSED 30 A.T.C.
.368 LIFT
VALVE CLEARANCE INTAKE .014 EXHAUST .016
