FWIW:
When I got my 1930 Model A coupe 55 years ago, the former owner/mechanic/neighbor had installed a homemade air filter attached to his Model A Sears Marvel carburetor.
As a daily driver, with 99% of traveling done on local, dusty gravel rural roads, (& with the nearest hard surface super highway 11 miles away), there was lots of road dust circulating every day.
This filter was made with an empty tin can that had multiple ice pick holes punched into it, whereby the interior filter material was a non-ferrous alloy "Brillo" pad soaked in clean engine oil, all of which was attached to the carburetor with a water hose clamp.
The former owner instructed me to remove the "Brillo" every 30 days & to rinse it in clean kerosene, which was then only 15 cents a gallon.
Even though this make-shift filter did not look like much, I remember the fresh clean kerosene turning jet black each time after cleaning the "Brillo" pad every 30 days.
Today with paved roads, we have lots less dust on our highways.
But then again, one may want to consider the inside a very clean, well sealed immaculate residence, & try removing the air conditioning filter to experiment how long will it take before one's interior A/C coil is plugged solid with dirt; or try using the same A/C filter for one year without changing same to experiment how much dirt can be collected with interior "clean" air.
Also, with low Model A mileage, filtered carburetor intake air may not make any difference in Model A engine wear in one's lifetime -- different opinions & thinking are sometimes helpful in making Model A decisions.
