1930 Tudor
Engine cranks when I attempt to start but still no spark. Followed Les Andrews diagnostics for ignition system
I bypassed ignition switch since it is broken. Using "emergency ignition jumper" available at Snyder.
I measure 6 volts at point when opened.
To me this means primary circuit of coil is good.
New coil so I am assuming secondary circuit is ok but not sure. Tried measuring resistance across primary and secondary but not getting reproducible readings. Doing it wrong or my meter is not working.
New condenser
Cleaned all electrical contacts
Checked timing of cam/rotor at TDC
Battery is good.
Placed "polarity and spark" tester in line with distributed cap and high tension wire from coil.
No lights which means no spark ( if I did it right) and suggestion is to review ignition system.
Would appreciate ideas. Thanks
New condenser
Battery is good.
