rivcokid
Good afternoon. My 1931 Fordor is having trouble with idle. Oftentimes (but not always) it will die on deceleration or at stop - it sounds like the idle is too slow. If I increase the idle, it doesn't, but the idle is too fast to shift without grinding gears.
I have cleaned out the fuel line, carburetor, and sediment bowl. I have confirmed that the float level is fine and there is nothing getting into it. I have sprayed starter fluid around the manifolds with no change in engine speed either way. The idle screw on the top of the carb has been adjusted per the blue book and it runs fine - in fact, the engine runs great other than the occasional dying on deceleration and/or stop.
I thought I had fixed the issue when I enriched the gas mixture with the GAV - it ran great for several minutes, then went back to its old ways!
Any other ideas beyond what I have tried?
