M meskhov Member Oct 19, 2012 #1 Just found this in some tools I bought at the fleamarket. Can anyone tell me what this reams on a Model A? It is a .625" size. Thanks
BRENT in 10-uh-C Well-known member Oct 19, 2012 #2 I don't think it fits anything on an A that I can recall. The brake actuating shafts are .559 and the next closest is the rear brake shaft at .688.
deuce5wndw Well-known member Oct 19, 2012 #3 By the 8520 number would it be for a water pump? The water pump number is 8501.
Craig Lewis Well-known member Oct 19, 2012 #4 meskhov said: Just found this in some tools I bought at the fleamarket. Can anyone tell me what this reams on a Model A? It is a .625" size. Thanks Click to expand... Steven's made firearms since before 1870...just saying...
Mark W. Senior Member Oct 22, 2012 #5 What is the wrist-pin diameter? I'm thinking piston bushings maybe?
SteveB31 Well-known member Oct 22, 2012 #6 Water pump rear bushing is A8520. Water pump shaft is .625.
RonC Well-known member Oct 23, 2012 #7 If it was a water pump reamer wouldn't the reamer size have to be larger than .625 pump shaft size?
