Brother A
I have about 6" of play in my steering wheel which makes the car tricky to steer. I have done the steering box adjustments as per Les Andrews with the exception that the box was in the car when I did that. The box was leaking when I bought the car so I'm worried that it may have been used with little or no lubrication. The leak is now repaired and the box is filled with Penrite steering lube. The Pittman shaft nut is very tight - no slop between the gear shaft and arm . Am I looking at a new sector gear or is there a simpler fix I should try first? Thanks in advance for your help.
Steve
Steve
