Steers Awful Bad...
baba
Rebuilt my front end because it steered bad. Sort of a binding situation. New kingpins, one had been installed without reaming the bushings (hence the binding) all back together and worse than ever. Takes quite a bit of effort to turn the wheel. Checked to see if the weight of the car is on the thrust bearings and guess it must be since I cannot turn them by hand unless the front end is jacked up, so guess they are doing their job. Mechanic friend suggested the tie rod may be adjusted poorly and the linkage is fighting each other (his words). I did have it all apart so he might be right. Have been looking at Paul Shinny's;s videos and may try seeing if the toe in is off.
Any ideas appreciated...
Steering problems in a model A Can be diverse and complex. Installed the king pin without reaming? How'd they do that?.......... Get a BFH and start pounding? ( BFH, Big Fornicating Hammer!) The balls on the ends of the steering arms is another good place to look. Some of the "Balls' don't look like they ever were balls, trust me, they were! I have no idea what condition your steering box is in. This may be the cause of your problem also. Check those steering balls first and get a king pin set and FIT the kingpins/steering bolts first. Steering ball diameter is 1.000" all around -.020. If you don't have a micrometer, They are usually available in a flea market at minimal cost, $5 to 10. for a good one.
Terry
The thrust bearings will need washers so that they work as designed. The washers go under the thrust bearing and the trust bearings are located on top of the spindle.
Break down the steering into the components. Remove the drag link and try the steering box. Remove the tie rod and then try to move the wheels back and forth with the axle jacked up. As you add back components, try the steering to see if that added component is the problem.
Removed the drag link from the drivers side wheel and the wheels turn easily. Where the drag link is attached to the pitman arm is apparently the problem.The slotted nut was driven in too tight and is now disassembled on the bench. Wheels are turning freely connected by the tie rod. Strangly, it was turned in only far enough to allow the cotter pin to go in but it was wicked tight. Not sure why it was binding?
What year and type of steering box do you have? I've seen spindle bolt repair sets that came with bronze thrust washers instead of the ball bearing thrust bearings. They steer a lot better with the ball type thrust bearings. The spindle bolt to spindle bushing should push in easily by hand for a light push fit. Sloppy or tight fits are problematic. The bolt should never have to be driven in. If reamed too loose then they will wear out faster. The tie rod and drag link ends should not be too tight is properly adjusted. This link sheds some light on ball & socket fit with spring compression for drag link & pitman arm ends. The 25% spring compression may be a bit tight depending on condition of all the parts.
https://www.fordbarn.com/forum/showthread.php?t=37639
Also make sure the front spring is not worn so bad that the tie rod makes contact with the pitman arm.
29, 7 tooth box. No contact between any of the moving parts. A real mystery. As I mentioned the connection at the pitman arm ball seems to have been way too tight, but only enough to get the cotter pin in. I looked for some kind of foreign object when I took it apart but it all seems to be as it should.
Steering can be AWFUL if the king pins are too tight in the bushings. I made that mistake once and it took an experienced mechanic friend to put me onto the problem. To correct it, I took it all apart again and used the unworn part of the old king pin that goes into the axle and some lapping paste to take the binding out of it. Once that was done, it was heaven.
I like the idea of a 2 tooth assembly. No problem getting it to fit?
I check all of my springs and they are all the same dimension.
I have two Model A’s, an early ’28 open cab pickup and a later ’28 roadster. Both cars have 7-tooth steering boxes. Decades ago, around the mid-1990s I adjusted these boxes as well as I could and had the steering balls on both replaced. I also installed E-Z Steer Teflon kits on the steering arms and drag links. I’m 87 now and have lost a lot of strength but I still feel that both cars are easy to steer unless at a complete stop.
Wow, Robert, you and I are pretty much the same vintage. I am 88 and the loss of upper body strength is awful. I have been agonizing but decided to pull my front end apart again after installing new king pins and all. I will go through the steps again and see if I can find where I went wrong. Hang in there. Is Burton anywhere near Ft. Hood? I spent a year or so there in the middle 50s.
baba, Burton is a small town with a population of around 300 or so. My place is about 10 miles from there and the post office uses that address. It is about 94 miles north west of Houston. I took my basic training in Fort Carson CO in the 50's. Good luck with your front end work.
