If you just need to move the seat back, there should be a piece of wood about 1 1/2 wide attached to the package tray. There should also be some brackets on the floor that can be moved. Remove or move those two things and you will gain some space. It is discussed in the service bulletins on page 257. If you also need the steering wheel raised, the suggestions above are good.
