steering wheel
FORDNUT
New member
I dug an old Superior steering wheel from my junk bin but do not have the adapter. Anybody know if this wheel will bolt to a Grant adapter which I can find? Going on a 63/64 Galaxie column which is going in my 57 Custom 300.
If you have a question about your car ask in one of the forums. There are 4 sections Model T, Model A, Early V8 and Late V8. The posting on those 4 is more directed to stock type cars and trucks.
If it's a customizing type question try;
http://www.jalopyjournal.com/
If you have a 32 to 34 4 cylinder engine question try the Model A section.
The editors/owners do not answer car questions.
Is that why it says questions in the header to this section?
Please read the whole heading,
The Ford Barn > To The Editors > then it says Questions & Suggestions.
In your case, when you went to www.fordbarn.com, on the homepage on the top there is "the forums". Click on that and you get the very first page of forums. The first section is General Discussion. This is what you want, to discuss the steering wheel for late Ford.
You would then go the late V8 and post your question there. If you look at the area you are now in you will see that you are far from the only one to make the error. I'm simply pointing you to the correct section to get the best answer for you.
While, as I mentioned, this forum leans towards the stock configuration of the Fords, there are knowledgeable people here to help.
Good luck with getting the answers you need and welcome to the barn.
