I have my 7 tooth in pieces and on my work bench. I'm waiting on parts that were ordered and cleaning up the column and related parts getting reused. Some things I've observed as I was taking it apart, and this 7 tooth setup is the least desirable steering box made in my opinion. The sector shaft on mine was not sealed on the end, no o-ring on the end as the vendors now offer. Oil would have leaked out in a matter of days. The upper bushing on the steering shaft bushing is above the upper grease fitting. I have to question this design as my upper bushing showed the most wear of any place. The sector and pinion have no adjustment to take up clearance or lash between the gears in the centered position. There is an adjustment screw on the end of the sector shaft to take up end play. There are shims on the lower steering shaft bushing between it and the end of the column to take up end play on the pinion shaft, those have now been replaced with gaskets in the kit. There are thrust bearings on each side of the pinion gear same as what are on your front axle kingpins.There were only 3 brass shims left in mine and I suspect there might have been some already taken out in the past. Also my steering shaft has a lot of wear, and is rough probably a lack of lubrication. Down on the bottom end where your light switch mounts, there is a fitting with a felt washer that acts as a seal. Mine had chewed into the end of the steering shaft probably due to end play or it had been previously over tightened by someone that didn't know that the felt should have been replaced. Most of the vendors offer a fitting with a brass tube that pretty much goes up along the light switch rod inside of the steering shaft to help keep the lube from leaking down in the switch, but I think it could have been made longer, I'm sure I'm wrong as a longer tube might bind. To me it would be worth a try. I'm trying to not reengineer this steering box, but I'm considering welding a boss for a lube fitting or vent about the middle of the upper shaft bushing to be sure there is always lube up there. Lets face it, shafts and bushings are only going to last for a certain length of time, but I'm sure good maintenance will help a lot. I'll try posting pictures later now that I see somebody else is asking about a 7 tooth steering.
There is a reason a lot of people ditch the 7 tooth box and buy a F100 from Randy @ Mel's Model A. If you are going for fine point judging then that's another thing.
