One caveat to my suggestion about tightening the end plugs in the tie rod - If you need to turn them in more than 1/2 turn, you had better recheck the toe-in adjustment. Tightening the end plugs deeper into the tie rod's ends will create a toe-out situation because by tightening those plugs inward, you are pulling the back of the tires closer to each other. That means a toe-in adjustment will be necessary to restore the factory spec's of 1/16" to 3/32" toe-IN.
Loose tie rod and drag link plugs will cause slop at the steering wheel. Jack the front end up and have someone turn the steering wheel back and forth while you watch the action of the pitman arm, drag link and tie rod. If the pitman moves, but the drag link is delayed in following, the end plugs need to be tightened. Do the same for the tie rod and watch the steering arm movement. If the arms begin to move but the tie rod delays, the end plugs need to be tightened. Tighten all four end plugs so that with a vise grips attached to each rod, you should be able to slightly rotate the rods with some resistance. If you can't twist the rods with a vise grip, the end plugs are too tight. An old Ford dealership mechanic taught me this trick 45 years ago. It works and takes the guesswork out of figuring spring compressions.
Marshall
