Steering Time
marc hildebrant
Group,
The Les Andrews book warns against using grease in the steering box. The user should use just 600 W oil.
Anyone know why this could be a problem ?
Regards,
Marc
Marc,the best answer I can give you is the 600W oil has a clinging agent added to it and will stay on the teeth where grease will squish out and cause metal to metal contact.
The 600 w steam engine oil stays on the gears as Jim says.
I plain 'O say 600 w oil is just too darn thick to flow past any seal. It's like leakless oil :-}
skip.
