Vic in E-TN
A few weeks ago I posted a question or two about the king pin bushings and the difference in the inner paths for the lubricant. There were good answers and I learned a lot. Over the last 20 years I accumulated about 10 pairs of spindles. I set up two to use to paint wheels and another to use in balancing wheels and tires. I have been helping out my club, the Smoky Mountain Model A Club in our spring tune ups. I have looked at several cars to reset the brakes, bearings, etc and checked the tires on jack stands for side to side movement and top and bottom movement. I found several top and bottom movements that indicated king pin looseness. I spent some time writing up an article for our monthly newsletter. I was asking for responses and am expecting to get more. There is a need to replace some bushings. The cost to purchase from the vendors a bushing reamer will be near $300. We will see what we do for a club tool. The bushings need to be honed to get the correct fit. Today I went to one machine shop to see if they could hone the bushings. Their price was $50 to hone 4 bushings. I have never seen what a bushing honing machine is and I thought their price was excessive. The bushing reamer has not been purchased yet.
Can anyone describe the necessary machine or method to use? I measured a new set of king pins and used some 320 and 600 grit wet sandpaper on a 0.75 in dowel rod to play with one of the old spindles to get a good fit.
Any help will be appreciated.
Thanks,
Vic
Thanks,
Vic
