Ken Model A
New member
Well, I did it now. I am working on a 1930 Fordoor steering column. This has been setting in a barn since 1960. The throttle and spark advance rods are froze. The steering column is out of the car. When using a puller on the steering wheel, the steering shaft split. I realize the shaft is done, but I would like to save the steering wheel. I made a shaft and collar to fit inside of the steering shaft so I can press on the shaft. I did measure the extended length of the shaft before I split it so I can verify the length. So, do I just keep the pressure on the steering wheel and tap the puller as normal to remove the wheel? Is there a better way? Thanks, Ken
