AKsportcoupe
Hi Ford Barners
I need to address my sport coupe's rattling spark and throttle rods. They make a terrible racket. I would rather not take out my entire steering column unless absolutely necessary. It seems that I should be able to loosen the column, then remove the horn rod out the back of the fold up top window, remove the steering wheel and then pull out the rods and steering housing leaving the actual steering shaft still connected to the gear box. Does this sound possible, or would it be easier to just remove the entire thing?
