Here's a few new guy questions about my new to me modified 29 roadster:
1. The previous owner cut up the top of the steering column to attach a new style steering wheel (Ugh!) It looks like he cut back the outside sleeve, (sorry I don't know the proper term) cut off the tops of the spark advance and throttle adjustment, and beat up the keyed area where the original wheel went.
I don't really need the two adjusting arms, but I'd like an original wheel. What parts would I need? I figure I'll need a new steering shaft, but after that I'm clueless.
Would it be better to replace everything from the gear box up?
2. I read where Model A steering is "notchy". My steering works in a way, binds in certain areas of the turn and has a lot of play. I know this when I have the front tires jacked off the floor. With the weight on the wheels, I can turn left fine, but really fight to turn past a binding in the center and when I turn right, the steering column starts to screw out of the shaft. What's going on? I haven't driven a good running A so I don't have anything to compare with.
Thanks from a clueless new guy.
