steering problem
Lawrie
As I have posted I have been away in my 28 pickup, way out in the sticks, it went like a dream , but I had a self inflicted problem and gave myself one huge fright.
I have been driving since I was 13 yrs and never had a scare like this,
My A had developed a small issue with the brakes while away, not serious, but enough to annoy me, they squealed some times and in the morning when cold they juddered on the first few stops.
I thought ,I have only to use them a few times as there is no cities out here, and would look at them when I got home.BAD idea.
So doing 50 MPH on a narrow country road in amongst 3 and four trailer fuel semis, I call the driver behind me and tell him I will look for a spot to pull over and let him pass, seeing an entrance to a farm I indicate, start to turn in ,apply the brakes and a HUGE bang, next thing I'm nearly sideways in front of the truck, I get off the brakes and try to get into the driveway ,cut the corner and skid to a halt with brakes seemingly locked on.
After a coffee ,And underwear check. I have a look , left front brake rod is still pulling on, and the brake is locked on,
I back it off and have a look underneath and inside the brake drum, but nothing looks out of place , so gingerly We head off ,but man is it hard to keep straight.
750 ks later I'm home, so get it up on the stands and this is what I find
Loose perch on the left hand side ,even though the nut was still pinned.axle bent and twisted, the radius rod on the left side bent and twisted, perch bolt looks like it was loose in the taper on the radius rod.
So Im in the process of fitting my spares, nice checked axle, radius rod ,new perches ,etc.
Lesson, never drive with brakes that are not 100 %.
I think what happened was as I applied the brakes , the axle moved in the perch area and this then pulled the brakes full on on that side and looked it on,
Up until then my A was a pleasure to drive, steered lovely .brakes great,
Now I have a pile of mangled parts on the floor.
Lawrie
Hello, lucky this time, I have taken a few of those spring perches out and usually a most difficult project, drill , hammer and air chisel operation.Hopefully you have spares available, good luck on the repair.
My a has cast iron drums and woven linings that where installed new only 6 months ago and are contacting all the surface, Stock A brakes , before this self inflicted drama they worked great.
After a full weeks work, I have the front end all back in, just have to refit the brakes and do A wheel alignment,
The work involved , boring and sleaving all the holes in the axle as most were worn , I bore the axle out on the mill, then turn up a .020 thou wall sleeve from an old A axle and that allows me to get back to the original Ford sizes.
Its a lot of fiddly work but sure turns out nice.
I also found the lever the brake rod connects to on the left hand side was bent like a banana, so it got replaced from my spares.
Wayno, your not wrong there.
Hows your tank going?
We are planning on running the dragster again in the new year,
Bob , 8 left, I will look after them /
Lawrie
