I saw reference today on FB that an A owner is using Penrite steering lube to eliminate leakage. It sounds like the lube is more of a gel, and if its 1200 W, it obviously is quite viscous. So I checked the Restoration Supplies catalog. In spite of new gaskets, O-ring on the sector, light rod tube, etc., I have a leak and I don't want to have to pull the steering gear and try again. It seems like it'll be a possible fix. I'm using a 600W and STP mix that's still leaking.
Does anyone have any long term experience with the Penrite steering box lubricant? Would it work well in a box with needle bearings? with bushings?
Thanks
Thanks
