Steering kit instructions
Car Pit
I'm rebuilding my 2 tooth gearbox with a kit purchased with nearly everything but the main housing body. I have found this kit has several gaskets and an o-ring that were not on my original box and I don't see them all addressed in my les Andrews book. Are there more detailed instructions somewhere online that show where each of these seals go?
Thanks as always.
By the way, I did get that stubborn original worm gear off my steering shaft. My next challenge is dealing with the fact that the key and splines for the replacement gear were no where close to matching the original.
This is from Brattons Catalog,
Contains one end plate gasket, two large gaskets for sector housing to gear box, (there were two diameters used, test fit both gaskets for the correct size to be used). One 'O' ring to be used on sector shaft to seal against frame. Recess sector bushing 3/32" at frame end of sector housing for 'O' ring. One thin steel flat washer is used to keep the 'O' ring in place against the frame. If not using modern end plate (# 5280), then order horn rod gasket for end plate (# 5040).
Thanks so much for this reply - Brattons no longer around and 14 years later after this post I had the exact same question today
I assume the O ring is not to be installed on shaft next to frame if I have purchased the upgraded needle bearings and lip seal housing?
