I am working on a 1928 phaeton that was" fully restored" when purchased last month.
Have redone the brakes and kingpins so far so it is somewhat tight and will drive straight.
Checked all the fluids and noted that there is an alemite grease fitting on the steering box. Unscrewed the grease fitting and you guessed it...full of grease. Scraped as much out as I could through the 1/4 hole using a pencil and filled what I could with 600 wt oil. Anybody have any suggestions short of pulling the column and taking it all apart? I was thinking of filling it with thin oil, or Marvel Mystery oil, then when it runs out refilling with 600 wt. Open to any ideas??
Thank you
Thank you
