In spring I rebuilt the front end steering on my 30 Coupe. New king pins and bushings, and two new steering arms, and tie rod end kits. Everything works smooth and free. Before I hooked up the drag link I tried the steering wheel, It seemed a little tight and hard to turn. I put it together thinking I would do a complete rebuild later on the gear box. I have now rebuilt the gear box. AfterI installed the steering, I could hardley turn the steering at all with the front wheels off the ground. Althought the steering box was free on the bench after making all the adjustment per Les Andres book... Took the gear out, thinking the sector gear was worn , I replaced with a very slight worn used sector gear. Made all adjustments per the book on the bench, nice and free. Decide I would check each step of installation to see if I could find at what point something might be going wrong. Installed gear, try to turn wheel without drag link installed. very tigth and squeeked. Loosen nuts and just snug the two anchor bolts, better but still stiff. Loosen nuts alot and steering is free. Can not figure out why Tighting the gear bolts cause the binding. Has anyone ever incountered this? Note: the two mounting holes are worn slightly oblong. I have installed the O ring and washer on the shaft before installing in the chassis and centered the sector shaft in the opening before tighting. Any help appreicated! Iam currently driving with the two bolts snug and hard steering.
