steering dampner install
Init1
Just installed a VW steering dampner on my A V8 coupe
with a 40 axle and split bones,
F1 steering box.
It fit easily and has plenty of movement to handle the tie rod
swing back and forth. Plus it only cost $24!
It dramatically improved the searching and wandering common with this setup.
Now it's just the bias ply
tires...
F1 steering box.
tires...
Do you have a part # for it?
Tks
Here's mine. Comes with a clamp for the tie rod, and the other end is bushed and held to the frame with a bolt.
Did you get it from the VW.dealer or as a after market unit what year is it from ? I am very interested John.
I got one locally from Model A supplier in North island.
For fitting to 34 Coupe. Easy to fit up and pleased with result.
Recommend these steering dampers.
Phil NZ
A similar setup was used on some later model Ford trucks, I have driven trucks with steering dampers. You wouldn't know it was there except for the reduction in shimmy and wondering.
J.C Whitney sells them. Listed as steering stabilizers. Got on for my '41 about 15 yrs ago. Attaches between the axle and tie rod. works great. Believe mine was for an Ford Econoline van
It's for a vw beetle (bug) they were fitted to the torsion bar front end type, don't know if it was fitted to the McPherson strut ones (super beetle) not sure when they started using them but they were fitted to all the '60's ones.
Same part supplied as a kit from socal speed shop, for twice the price but does come with the fitting brackets I believe.
Martin.
I have install numerous steering shocks on old Fords. Make sure any damper installed has a long enough stroke so you get enough motion in both directions. Put the wheels straight ahead and put a chalk mark on the axle and one in line with that one on the tie rod. Turn the steering wheel all the way to the right and left marking the axle with the mark on the tie rod. The distance better the two outer marks is the stroke. Lets just say it is 10 inches then find a damper with a 12 inch stroke. When installing put the wheels straight ahead and extend the steering damper shaft 6 inches. This way you get the full turn range and have a little extra so it don't bottom out. I can leave my hands off the wheel at 70 MPH and the car tracks straight down the road. This addition is NOT installed the fix front end problems. Before installing with the wheels straight ahead and on the ground have someone turn the steering wheel past any play to the right and left while your under the car looking for any play at loose wheel bearings, lug nuts, king pins, tie rod ends, where the perch bolt goes through the top of the axle, the steering wheel bolted on tight, the mounting bolts of the steering box, the steering box mounting adaptor, steering box shaft bushing and play in the box gears. I bought a 40 coupe years ago and the steering wheel turned half way around in both directions before starting to turn. I found almost everyone of the above items loose, I fixed them with no parts and had perfect steering. Where the perch bolts go through the top of the axle look for a ring of rust, that indicates movement, The nut on the bottom is hard to turn and may need heat to get them to turn. G.M.
There are 2 types of VW Beetle dampners. One is for the early type 1 and the other is for Type 1 Super Beetles with Mcpherson struts. The only difference is the mounting ends. Both will work.
They can be found at any import parts store, VW parts houses, EBAY
Amazon or on-line VW speciality shops.
Some are Brazilian, some from Mexico, some German. They are all the same performance.
You won't feel anything in the steering except better road feel and
Less wandering.
I'll try to post pics soon...
