Steering Column Support
Ron/IA
I have a friend with a leaky steering column support at the gas tank on his 1930 Model A Tudor. I know there is a fix which puts the column mount on the dash; thus relieving the tank from the stress of the column.
I have not been able to locate this information (I did have it on my old computer, but it crashed).
Can anyone help me out?
Thanks,
Brent - No, the leak will have to be fixed (he is in the process now). I just wanted to show my friend how this problem could be avoided in the future, and then let him decide.
Anyone been able to find the info yet?
It will be much appreciated.
i think that late 31 model A's had a steering colomn support mounted off of the dash rail,therefore not putting stress on the gas tank.he could repair the leak,then add the 31 support with the original one not actually supporting the column.
Use the later 31 steering column suppot (available from the vendors) and it mounts up under the dash panel (Ibelieve to existing holes, may have to use spacer washers). Others more knowlegable may chime in. U could also do a search as this has been discussed in detail before.
Paul in CT
On a 30 the 31 support bolts on using two of the under dash bolts-no spacer needed. Also,don't use the bottom support as the two together can cause more problems. loosen the steering box and then tighten the 31 support.Leave the bottom bracket rubber cushion out and there won't be any strain on the tank.
Here is a Link from Mac's for the Bracket for a 1930-31. Mac's has a sale on this weekend, 10% off everything in their Catalog with the Code below
Use Promo Code "TURKEY10". Offer Ends November 30th, 2010​
http://macsautoparts.com/model-a-st...ile-steel-a3520/camid/MDA/cp/JS0R3CHL1096376/
You can add it to the 28-29 without drilling any extra holes in the car. Someone posted here before with pictures of how to do it. You take a samll plate that matches the holes behind the dashrail. Make some more hoels to match the drop and then you are good to go. I will see if I have it in my files.
All - Yes, the information you have supplied is exactly what I was looking for (and what I remembered after seeing said info).
I will make copies of the pictures, and part information.
Thanks,
