You probably would not have to do any changes as long as you don't pull on the steering wheel to get yourself into your car.
I'm sure you are right but I was thinking more of preventative maintenance. After all that steering wheel has been vibrating on the end of that shaft for 85+ years. Metal fatigue? Plus how many "pulled" on that wheel before I came into possessionFor me, it's worth a little peace of mind...
I have a bracket in both of my 1929's. You do have to drill another hole in the frame around the window to attach the upper end to the dash.
Also I found that there are two different length brackets and this I don't know why. Maybe one is 1930 and the other 1931???? I don't know but maybe someone on the Barn may know. I had to work over the second one I installed because it was a little longer than the first one but it did do the job.
