Randy1944
Now that my column drop is on the way, I would like to have help on removing steering column without doing much damage. First is how to remove horn button (I need it off so that I can install new horn wire). Will I need to remove steering wheel and then entire steering column and steering box? Maybe I can remove steering wheel and slide the column drop down over steering column? If needed, suggestions about pulling steering wheel, hopefully without damaging it.
Thanks
Thanks
