Steering column question
yooper trooper
I need to remove the bolt that clamps the steering column on my 1940 PU. It's the one that secures the column hanger/ ignition switch/ steering shaft lock. I've read where an easy out was used. suggestions please.
Thanks
I have always drilled a series of 1/16” holes across the head and used a screwdriver. You end up with a usable original bolt.
I'd suggest removing the gauge cluster so you better access the bolt. Through the gauge cluster opening, attempt a locking pliers. There is typically enough material remaining on that bolt to grasp it well. Nearly always, this method has worked for me. If not, cut a slot in the head of the shear bolt and use a screwdriver.
I seem to recall that I used a small pair of vise grips behind the dash to clamp onto the threaded end of the bolt that extends through the dash and was then able to turn the bolt enough so that I could clamp a pair of vise grips onto the head of the bolt and literally back it out. It's been about 40 years but, that's what I recall.
I hope we're talking about the same bolt. This is the one used to clamp the unit to the steering column itself. I don't see anything behind the dash. The unit is secured to underside lip of the dash by two nuts and bolts which are easy to get at.
