I am trying to install in 55 club sedan. What am I missing? When I slide the column over the steering shaft there is a space between the shaft and the I.D. of the column. Also when I put the steering wheel on, it hits the turn signal housing. Is there a roller bearing or bushing that goes at the top of the shaft to take up that space and stops the steering wheel when the retaining nut is installed?
also is there supposed to be a spacer or shim that goes between the steering column support and the brake peddle bracket?
Thanks Jim
Thanks Jim
