jack wingard
Newbie questions. How can I determine if I have 2 or 7 tooth box? Also I have grease fitting & not plugs this is correct is it?
Can you post a picture of what you have?
Charlie Stephens
If the sector shaft housing is bolted to main casting with four bolts its 2 tooth. Seven tooth has sector shaft housing as part of main casting.
