Hi, there is too much play in the steering. I have the box disassembled and on the perfectly tidy work bench. I see some wear on the sector shaft, is a little wear acceptable?
I believe the worm gear to be to be modern with 13 rollers.
Any advice on this appreciated.
I find that the difference between "too loose" and "too tight" when setting "just right" at the center of travel is very tricky to achieve. And if you are using the eccentric to set it, it will get knocked off when you tighten the jam nut. You may need to sneak up on it several times until you get it right. If I can't get it right on I generally set it on the tight side so that it can loosen in use....
Or - you can follow the instructions in the Service Manual for adjusting - and hope for the best. You want it TIGHT, almost galling at "mid span" and increasing but equal amounts of "free play" as the wheel is turned further from center.
Joe K
Somewhere there are instructions on how to adjust the box. Maybe the Red Book. I am not at home so I cannot check. If you cannot find instructions, it is not too hard to figure out.
