Very often I find those two mounting holes in the frame wallowed-out over-sized because of loose bolts and/or improperly sized bolts that had been installed. This allows the steering box to move against the frame, causing wandering and steering problems. Eventually, the steering box will drop a bit, causing the sector gear shaft to rub on the bottom of its exit hole. This creates hard steering until a groove has been worn into the shaft. Even then, it's metal against metal as the shaft turns. That can't be good! I think this is an over-looked cause of hard steering. I have removed numerous sector shafts over the years that had that telltale groove worn in them, always accompanied by wallowed-out mounting bolt holes and incorrect or loose mounting bolts.
There are two ways of correcting this condition that I have used, the second one rather ad hoc. The best way is to weld up the edges of the mounting holes and then carefully measure their relationship to the center of the sector shaft hole in the frame. Drill out the welded-up holes to the correct diameter so that when the mounting bolts are installed through the steering sector housing and frame, the shaft is centered in the hole. Grind away excess weld. Be sure to use the correct hardened fine thread bolts with castle nuts and cotter pins. Hardware store bolts will not be sufficient here, unless you use Grade 8 bolts. But then you lose the ability of using the castle nuts. I am not sure Grade 8 fine thread bolts of the required diameter are even available in your local hardware store. Why bother looking? Correct bolts and nuts are available from all Model A vendors.
The second way of correcting this problem is not as permanent, but will also work in a pinch if welding is not your forte. Since the holes in the frame are wallowed out, there is some fudge room with them. With the pitman arm removed, push the sector shaft (and hence steering box) up to where the shaft is centered in its frame hole. Shove a flat blade screwdriver underneath the shaft at its lowest point between the frame and the shaft to keep the shaft in place while the CORRECT bolts and nuts are tightened. And I mean TIGHTENED! Once tightened, remove the screwdriver and ensure that the sector shaft has clearance all around its circumference. The shaft should now be able to revolve freely without rubbing against the metal frame hole.
I suppose one could drill the holes in the sector housing oversized for the next bigger sized metric bolts. The frame holes may need to be equally drilled out to match, depending upon how wallowed out they are. If hardened fine thread metric bolts can be found, that would be better than coarse thread for gripping and holding strength. But then, of course, you lose the authenticity of castle nuts and cotter pins. Select a length bolt that will allow a lock washer between the frame and the bolt head, yet so that they will not rub the backside of the pitman arm as it turns.
Lots of different ways to skin a cat, if it needs to be skinned.
Marshall
ADDED: By the way, you'd be surprised at how many times I have encountered the mounting bolts installed backwards, where the nuts are on the INSIDE of the frame instead of where they are supposed to be = on the outside. How could someone installing the steering column possibly think that was the way the bolts were supposed to be mounted? For one thing, how in the heck would you install the cotter pins through the castle nuts? Jeez....
