Just drove it for the first time. I'd say the play is even better than I thought, it's under an inch. And this is on the old sector shaft and worm, with a new needle bearing sector housing, the above mentioned better housing to frame bolts, and a new pitman arm.
On the sector mesh adjustment, it's pretty darn good when centered, and there's just a smidge of resistance when turning wide. I'll take the trade-off, unless this is going to cause accelerated wear.
I'd say I had a few thousands pocketed/dimpled on the sector teeth, and just minimally noticeable like (.002) on one side of the sector shaft. While it would have been nice to get new parts, there's no telling when new sector shafts will be back available, and this looks like it's going to keep me driving for a good while on the old parts.
I'm trying out the Penrite no leak steering box lube. This stuff is slow to pour. Like crack a beer and come back tomorrow slow. It took several fills with a 1.5 oz threaded funnel I made up to fill the steering reservoir.
I put off this repair as I thought it would be a can of worms. Once I studied all the books I had and one DVD video (Diablo A's Rebuilding 2 Tooth Steering, highly recommended) the mystery of the steering gear was tackled and I felt like I knew how to both tear it down and adjust it once back together.
Oh, one more thing. If you know you're not replacing the worm, you can do all this without removing the entire steering gear from the car. I covered the pedals in a towel, put a mat over the seat brackets, and laid the wheel either on the seat or on the mat, depending on what I was doing. All I removed was the floorboards, and the starter. Then once it was off the frame, I slung the engine end of the gear with rope from the radiator to firewall rods. Even easier.
The car had 71,000 miles on the meter when I did the frame off restoration. What's the experts guess that that kind of small wear on the sector shaft being the original part?
