dubnutty
I’ve got a leak coming out of the base of my 7 tooth steering box. The cars a ‘29 Wagon. I removed the light rod and determined that the seal is bad. Now how do I fix this? I see a seal and a seal & tube from the venders. Which one should I use? Also will I have to remove the box for this repair? I included some pics to show what I’m describing. My car was missing the light switch and the horn rod knob was broken off. It was stuck in the steering shaft but I did finally get it out. Any help in the direction I need to go would be much appreciated.
