Dick Deegan
My situation is entirely different from the previous post on the same subject. I have just rebuilt my steering box with a complete kit from Bratton's. I have done all of the adjustments on the bench and reinstalled in car. My box is the early 1930 Gemmer 2 tooth with the 2 19/64" OD gasket between the housing and the sector housing. This arrangement was obviously a problem since the gasket was changed to a larger one with a modification to the housing as well.
I cannot keep oil in the box. I have tried 600W and 1500 oil from Mike's. They both leak badly. The leak is between the box and the sector housing where the above mentioned gasket is. This is very frustrating.
I have thought about using corn head grease in the box, but wanted to get some input here before I do it. I would try Penrite grease/oil but I haven't been able to locate a supplier in Canada.
What say you?
What say you?
